3 quick questions...pics inside
Old Sep 9, 2003 | 03:22 AM
scoobysnax83's Avatar
Number one: Is this the knock sensor that is broken off in my head here?
Number two: Is this gasket on the throttle body top ok to stick out a little bit. I cannot get that sucker to go in any more. Also is it supposed to be all stretched out inside? Its not cracked or ripped.
Number three: Can anybody possibly guess what kinda springs these are. I know that they can handle atleast a .540 lift if not more. They look to be blue. Just a long shot guess. I'm curious as I just bought these heads with springs already on.
Thanks for all the help......
Old Sep 9, 2003 | 03:31 AM
SStrokerAce's Avatar
The springs look like a Comp spring. The only way to tell is put them on a spring pressure tester and see what they read at two heights like 1.800 and 1.200
If you want to get that gasket on, get out a Torx wrench and take that plate off and that should make it much easier.
The broken sensor is not a Knock sensor, it should be a water/coolant temp sensor.
Bret
Old Sep 9, 2003 | 06:29 AM
DR.ZED's Avatar
Bret
To expand on what Bret said, its the sensor in the driver's side head which controls the position of the temperature gauge on the instrument cluster. It does not interface with the PCM, that sensor is in the waterpump.
My gasket on the TB top plate, did the same thing. I bought a new one, and still even then it was not perfect. No problems, at all, as long as you tighten down the rubber in some sequence to get a nice clamp. That gasket comes with one other gasket and is in expensive.
Old Sep 9, 2003 | 06:52 AM
thanks for the help. Its all going back on the car today. The cam is already in. I just need to buy new wires. I have to wait almost a month for my AS&M's. What do you think my car is going to run like. It will have all the items in the sig. I'm waiting on 30lbs svo's as well, after I get them both I will send the computer for programming. What will it run like in the mean time.....
Old Sep 9, 2003 | 07:48 AM
You can get the TB gasket in this kit.
Old Sep 9, 2003 | 07:52 AM
93ZM6Tally's Avatar
Also comes in the Felpro intake manifold gasket available at AutoZone, EGR and of course intake manifold gaskets too.
Old Sep 9, 2003 | 11:32 AM
quicksilver97ta's Avatar
Everybody (almost) breaks that coolant sensor. I did, bought a new one at O'Reily for ~$6. That t.b. gasket is also a common problem. You can buy a new one or just remove it completly and use just tad of sealant on the perimeter of the top plate. All the gasket material on the inside is not necessary, just seal the perimeter and your good.
68camaroboltz
Oct 5, 2015 11:56 PM
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 09:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
