View Full Version : LT1 Based Engine Tech
- Fuel line help PLEASE
- hyper tech problem
- **ignition Problem Shoebox/injuneer**
- Head Milling Question
- Whats the absoloute best adjustable fuel pressure regulator
- Whats the part # for the 1LE driveshaft?
- can't figure out the problem
- Lt4 Conversion Kit Vs. Lt1 Ported Heads
- ???ses Light Flashes After Driving For 5-10 Min
- K&N FIPKII w/ Traction Control?
- CC304 with stock stall
- cc305 and cc306 users... gas mileage needed
- Hot cam and A4/2.73`s
- I want to run 12.7
- Xe230/236 vs. cc306
- 230/236 XE cam on stock heads and stock stall...
- Which cam?
- Heater Core Question
- Pros/Cons of Cloyes double roller timing chain on stock engine.
- Couple tech questions inside. Stuttering and rev limter
- What does the cc306 peak at (rpm) with 1.6 RR and stock heads?
- Looking to go over the car during the winter, but need help
- Replacement of Muffler needed?
- How much torque on oil pump cover bolts?
- opti install
- gas mileage question
- Timeing chain, help please!
- Took out MAF Screen, now smoking?
- General Questions
- Quick PCV/burning oil ?
- Power Steering Cooler Questions
- Intake manifold bolt hole size?
- How to figure out compression ratios
- Engine removal problems???
- Timing chain cover
- Lloyd Elliott's phone #?
- Need help picking cam.
- What's the biggest cam I can run with 1.7 rockers?
- Timing Chain?
- What car do I have?
- Update on a bad car rebuild
- Whats the difference between Low and High Z injectors???
- F.I. LT1 to carb, any good websites?
- Kook's 1 7/8" headers now installed - info/thoughts inside
- What to do with fuel rail to get the Corvette F/R covers to fit?
- Cutouts and lowering
- PCM tune?
- Good points and bad points of these CAI's?
- idling high
- 227 comp stats...
- 383
- Intake manifold and questions
- Anyone used this damper
- car problems help
- How do i know if i need a FPR?
- better numbers now?
- Stock Heads + CC306 + TH350 w/3800stall equals????
- Dyno Results from CMS package...
- Engine Gaskets
- Code help.
- What size shim to use for the starter?
- Cap and rotor shot?
- ? about a few problems
- Is it normal to pick up almost 40rwph after converter lockup?
- What header gasket for ported heads?
- Almost done...
- What Cam?
- Stumble Problem
- Silly battery charging question - no posts??
- LT1 Starter on strike for winter?
- Mileage
- 98+ engine in a 97???
- Newbie Here......
- Spark tester.... how much gap?
- Injectors Guru's inside!
- Getting the timing cover off
- Valvetrain Inquiry
- California residents, chip in about emissions testing for a newcomer
- 313.66rwhp and 334rwtq with bolton's
- Well i'll be darned......
- Ok so which is it that makes the headers glow? Rich or Lean?!!
- lt1 engine rebuild question
- cc306 cam card with 114 lsa
- Speedo wrong! I need RPM vs. MPH chart for M6
- Edelbrock LT1 performer intake
- Bogging at WOT and then bam back to normal.
- How did you stop
- Car won't start HELP!
- CC306 cam card
- Lifters?
- Beating cam surge
- Anyone have STOCK LT1 heads laying around, need quick measurement!!>>
- Pulled the Opti and WHAT THE HELL??
- Help Troubleshoot possible fuel problem
- How are 93 headers different from the 94-95?
- Sts Rear Turbo Discount
- Thinking of adding A STS rear TURBO
- where is my pcm located
- 4.10's and trap RPM
- v6 to v8?
- Lt1 Ls1 Engine Swap
- Overheating
- autolite 104's
- which locks for K-800's?
- 2.73`s cross the line in 2nd or 3rd?
- LT1 Heads and LT4 Intake, whats the big differences (performance/physical)?
- Oil pump drive assy.
- Port heads for blower. worth it?
- stock LT1 heads
- LE2 cam -vs- 227/233
- Odometer lights are going dim???
- Opti? Fuel Pump? Help me diagnose my "die after start" problem..
- headers and tires
- who has the cheapest/best exhaust cones
- What am I forgetting for cam install?
- plug wire,, pic inside
- Car Failing to Start -- Looking for help
- Did i buy the wrong valve springs?
- Headers and tune or Nitrous
- Strange cooling problem!
- New Engine Specs.
- Does the PCM throw a code when one of the injectors isn't firing?
- is everyone else tired of the hit or miss luck with adjusting valves?
- What took to get the balancer hub off?
- Can anyone give me a diagnosis
- No Cruise Control
- Need some part numbers...
- 109.5 MPH Traps ->
- Whats WRONG???!?!??!?!?!?
- LT1_Edit: how to disregard O2 sensors
- LT1 Newbie
- Car wont start
- header gaskets keep blowing
- Anyone know the part number for rear abs sensor for non TCS cars?
- What to do for dipstick with TH350???
- water pump drive gear
- setting fuel pressure, aftermarket fuel system
- Code effect performance???
- 1.6 rockers with stock springs/cam...
- Took my new 383 for a spin, mod list inside
- LT1 R&R engine guide
- I think I have an idea why my opty lasted sooo long
- Those who have had opti's fail.....
- 35 Ft lbs for Tie Rod end nuts. Its that enough?
- 99 malibu injectors in an lt1?
- Questions about Pacesetter LT's
- LS1 swap
- High Bolton dyno #'s but car is a turd!
- 1.6 intake/1.7 exhaust
- what should i do to my lt1
- header emissions fitting ?
- opti
- Hole in intake
- Need to figure out gas mileage problem
- MAF question
- Locked up motor, Plans to get it going again
- Can't Get Off Y-Pipe Nut-Need Help
- GMPP vs Comp guideplates?
- Why do some buy non-vented optis?
- TPIS ZZ409 Cam
- Another pleased Delteq customer
- Smell gas in my car at speeds of 60mph +
- Looking for a connector
- Need help replacing serpentine belt, where's the tensioner?
- opti part #
- HELP!!! possible opti spark problem
- Blowing gauge fuses
- What exhaust to get
- Broken Tranny mount
- Would a Firebird bumper fit on a Camaro bumper?
- Where to Buy Good "Matching" Heads and Cam and Intake for ~425 RWHP 396?
- where to get fidanza aluminum flywheel cheap? anyone?
- cold start problems
- removing engine from the top on 96 z, need help
- Where to buy Mr.Gasket .026" head gaskets?
- SLP 1.75" sorties vs. Long tube headers ?
- More Improvement on my times , what yall think... ?
- They weren't kidding...
- Very Important question about PUSHRODS. Motor might me DEAD!!!!!!
- it runs!
- Car is back firing then dying??? Ignition problems maybe?
- Serpentine Belt
- Problems with car.. help please
- new to fbody world..have ?? about my 95 t/a
- head/cam total cost?
- Is this supposed to be like this?
- Car won't start after changing wp
- Whats the correct Ft. Lbs torque for roller rocker studs?
- Hi Idle
- Opti died after 1 day!!
- Have to give the car gas to start, but I am fuel injected!!! Help
- opinion on combo
- Cam help
- Fuel Pressure
- Runs fine in open loop, but stumbles badly in closed loop?
- car sat outside for 7 days, now wont start?
- comparable cam to cc306
- what to do to hit 12.5
- anybody who has removed cruise control i need help
- Quick, lost coolant temperature sensor wire.
- Who is Llyod Elliot?
- How to tell which way to reinstall crank hub???
- Finally replaced the Hooker cat-back with the GMMG today...
- Most RPM on stock LT1
- How does this setup sound?
- Bosch 30# flow on stock system
- Need help with starting problem.....
- Anyone running Electric Water Pump with 3spd (TH350/400)???
- Wheres the cheapest place to get Lt4 valve covers and how much are they going for?
- do i need new valve covers?
- PCM Questions
- Porting MAF ENDS
- Simple overhaul ?s
- Electrical Problem - Need Help!!
- coolant temperature wiring pigtail
- How much for lt1 rebuild?
- Predict my quarter mile!!!
- Is Granatelli fuel pump a cheapest stock fuel pump replacement?
- whats the stock muffler size?
- EGR behind the intake...
- push rod order?
- SLP y-pipe not fitting with Canton 242-T HELP!
- TH350 Questions (torque arm mount, speedo, using elect w/p w/3.73's) HELP!
- spin tech or loudmouth?
- slp loudmouth for 1997?
- What cam to use to acheive 475-500 rwhp in my 396?
- Stock GM timing chain work with Hot Cam ?
- How much to ship a converter?
- what could be the problem?
- Putting this thing back together
- Help identifying a component on a '96 Trans AM
- understanding matching HEADS to CAM, besides lift
- what do you guys think of this.filtermag
- Looking for aftermarket exhuast - quiet?
- Need help removing and installing exhaust manifolds
- Last Time, Header install question.
- LT1 LS1 engine swap
- Should I remove throttle body to clean it?
- Baseline RWHP '94 six spd vs. Hot cam, SLP & PCM
- need part # for T-56 slave Gm slave unit!!
- MSD Ignition LT1 Distributor Cap and Rotor Kits (OPTI)
- ! O2's
- CKP - Reading a Negative 15???
- Putting motor in from bottom, can you leave headers on???
- racetronix fuel pump in ls1 tank, in lt1 car
- How fast have you gone on the stock 10 bolt rear?
- 95 Hard start and no throttle response
- Opti, cap, rotor...i'm confused.
- White smoke pouring out of exhaust!
- Flexplate swap help
