230/236 XE cam on stock heads and stock stall...
It says to use the cam with aftermarket heads and stall. What would be the effect of that cam on a stock stall and stock heads.
Would the springs, lifters, rocker arms, etc. have to be changed?
Re: 230/236 XE cam on stock heads and stock stall...
It will be like eating ice cream thru a straw
will more then likely stall in drive, you'll have no power, or you will need to rev the crap out of it to take off
Contact some Supporting Vendors for what you need...
Just to name a few....they will help ya out with a package...
Thunder Racing
Speed Engineering
Thunder Racing
Speed Engineering
Thunder Racing
Speed Engineering
Thunder Racing
Speed Engineering
When choosing a cam, remember you have to match more then just what the specs say.
Almost forgot, you'll maybe need gears too.
Not trying to sway your decision, just schooling you a little as what is involved with going with a cam like that..
Go with a cc305 and you will only need pushrods, springs, retainers, and a tune.
Originally Posted by WayneE
I'd worry about emissions in MD, Mohsen.
I already have a prob with that, took the test 4 times last time and i still had to "encourage" the guy before i passed...Hows it goin Wayne
