What's the biggest cam I can run with 1.7 rockers?
Im going to do a cam and 1.7 rockers in the spring, Whats the biggest cam I can run with 1.7s safely? I was leaning toward the cc306, would that be too much lift on stock heads? And is the gm847 too much for this setup with stock heads? thanks
Re: What's the biggest cam I can run with 1.7 rockers?
The stock heads don't gain in flow after .500 lift so there really isn't any point running tons of lift on stock heads. I see lots of negatives in running 1.7's. 1.7's and a cc306 or gm847 would be lots and lots of lift and you would need some badass valve springs. Why not just run some 1.6's.
oldschool
Feb 9, 2016 09:21 PM
