95 Hard start and no throttle response
Old Dec 10, 2004 | 09:39 AM
lillbush5555's Avatar
Question 95 Hard start and no throttle response
I got a buddy with a 95 Z and it is all STOCK anyway when he goes to cran kit up in the morning it turns over but wont fire. when it does fire it runs. Yesterday when he was coming home from school he said he was going 20 in 1st gear and was giving it gas but it wasnt going anywhere. Now I told him it is prob the opti but he is strapped for cash and it is his only car and I dont want to have him buy a opti if that isnt it. what do you guys think it is? I am pretty sure I am right but want to double check 1st.
Matt
Old Dec 10, 2004 | 10:41 AM
xxsaint69x's Avatar
Re: 95 Hard start and no throttle response
fuel pump..check fuel pressure.
Marcin
Old Dec 10, 2004 | 11:53 AM
TobyZ28's Avatar
Might be a clogged cat too... My 95 did a similar thing...
Old Dec 10, 2004 | 12:36 PM
gunter96ws6's Avatar
its my little brother, it has a brand new cat so i dont think that would be it. im stumped~gunter
Old Dec 10, 2004 | 01:36 PM
camaro325's Avatar
I would check fuel pressure and and see how fast it drops,I had rough starting and didn't fix it till my starter wore out, it turns out I wasn't holding pressure in the fuel pump, so If I were you I would make sure it holds pressure, accept in your case it sounds like it may be a bad injector due to the rough starting and sluggish running, also check regulator (pull off vaccume hose while car is running, and pressure should go up)
Old Dec 10, 2004 | 02:00 PM
SVWHAT's Avatar
I suppose this is going to be a guessing game. I'll go with the Ignition Module. Actually it could also be the coil itself. I'll go with the first response. My car did the exact same thing pretty easy fix.
Old Dec 10, 2004 | 03:34 PM
RoMaD's Avatar
As much as everyone wants to blame the opti for everything (and it's definitely deserving), I would check the easy (read: cheap) stuff first. Unless you changed that fuel filter yourself, that should be the first to go. Next would be the coil. In my experience, the ignition module is an all or nothing item. It either works or it doesn't, not a lot of gray area. The coil and filter won't run you much and if they're still stock, they need to be replaced anyway.
When you have the coil off, just make sure you clean the ignition module and make sure it's getting good contact. Last, check all your ground wires for corrosion. I had to reterminate all of mine after a little episode with my old Accel coil.
I would lean toward more of a fuel problem as others have said, but the cheapest thing is to replace the filter. Even if you get low pressure on a check, you'll want to start there.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
