Intake manifold bolt hole size?
Old Dec 15, 2004 | 10:12 AM
Mullet Z28's Avatar
What's the size of the bolt holes on the intake manifold? I'm having some alignment issues. Most of the bolt will go in, but a few are just slightly off, so I want to drill the hole out to the next larger size.
I think the actual intake manifold bolts are 3/8, but want to know what the actual size of the bolt holes are. Would they also be 3/8?
Old Dec 15, 2004 | 11:04 AM
Re: Intake manifold bolt hole size?
A quick check with a digital caliper shows them to be in the range of 0.435-0.445". That would be about 7/16". The next size up would be 15/32" (0.46875"). Why are you having alignment problems? Were your heads cut?
Old Dec 15, 2004 | 11:20 AM
Mullet Z28's Avatar
Thanks for the help, Fred. As always, you're a big help.
The heads have been cut several times. At first alignment was way off, so I cut down the intake manifold flange also. It's much better now. Most of the bolts will go in and thread properly, but a few are just slightly off.
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
Joes96z
Dec 13, 2014 07:48 PM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
