Hi Idle
Old Dec 11, 2004 | 09:50 PM
Dave19yz28's Avatar
Hi Idle
Hey guys, car is having some issues....let me know what you think could be the culprit.
The car idles high, around 1000-1100 usually. When I push in the clutch to downshift, the revs sometimes jump up to the 2500ish range, then slowly come back down to around 1000. I noticed the other day in traffic, i was in 1st gear, foot on neither clutch gas (speed was ~10-15mph) and the car was accelerating ever so slightly up a hill.
I thought it might ahve been the IAC, or maybe the IAT, ar maybe a throttle cable getting stuck somehow....any thought?
Thanks in advance, sorry for the long post.
Old Dec 11, 2004 | 10:11 PM
NineD3Z's Avatar
Re: Hi Idle
Check the TB maybe something is making it stick? and the cables while ur there. Not sure but could the TPS cause that?
Old Dec 11, 2004 | 10:33 PM
Dave19yz28's Avatar
Re: Hi Idle
Not sure, but i will be sure to check on monday (not at home this weekend)
any other ideas?
Old Dec 12, 2004 | 01:16 AM
DavesLT1's Avatar
Re: Hi Idle
I had the same problem and changing my TPS solved it. check your TPS by taking it off and using a wide flat tip horizontally and turning it 90 degrees counter clockwise. If the screw driverblade is wide enough but doesn't catch the teeth in the TPS you need a new one, or if it is hard to turn or when you let go it doesn't snap back to it's original position it is worn and you need a new one. Mine cost about $30 after tax at Checker. Though this isn't to say something else may not be wrong.
Old Dec 12, 2004 | 01:02 PM
OBE1 95Z28's Avatar
Re: Hi Idle
Did you clean your TB recently? After I cleaned mine, my rpms would hang. Dab some oil on the butterfly rod where the rod enters the housing.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
