Beating cam surge
Old Dec 14, 2004 | 07:13 AM
grygst76's Avatar
Beating cam surge
I was under the assumption that NGK TR55's were a great plug; so i switched from autolite 104's to the NGK's. Well now I have cam surge so bad under 2200 that I don't even want to drive my car anymore
My gap is set to .50 on the NGK's and on the 104's I gapped to .45.
What is a plug you guy's with the bigger cams are running that gives you very little cam surge??
Old Dec 14, 2004 | 01:20 PM
Spinner's Avatar
Re: Beating cam surge
I use autolite 104s... if you want to lessen the surge, turn your idle up a bit.
Old Dec 14, 2004 | 01:59 PM
Cwynn's Avatar
Cam surge has nothing to do with spark plugs, if it is running rough under 2200rpms, you may have an ignition miss among other problems.
Old Dec 14, 2004 | 02:05 PM
grygst76's Avatar
It runs fine, just cam surge is definitely there,,,, pulls extremely hard after 2300 RPM's and if I give it gas, but if I baby it it surges horribly. so that rules out the miss. Seems it was much better with the autolite plugs in the car, I had very minimal surge..
Old Dec 14, 2004 | 06:17 PM
brain's Avatar
What size cam are your running? I have a Gm847 on stock heads and my car doesn't have cam surge as low as 1700. I was very surprised. Have you had the car tuned? Mine is a Madwolf mail order tune as well. Also, what gears are you running? With the 847, 4.10s are a big help.
Old Dec 14, 2004 | 07:41 PM
TheBiz's Avatar
I run the ACDelco platinums in mine with not problem. The cam serge may be a result of a tuning problem. I don't have any drivability problems. That is if you consider the cc306 a heavy cam?
I saw the HP/TQ numbers after your head/cam mods. What exactly are your mods? Could you list them, I'm curious what you have.
Old Dec 15, 2004 | 05:12 AM
grygst76's Avatar
My tune is pcm4less
mods are simple ones MAC headers; no cats
thunder racing MAF
no air
cai
comp r lifters 1.5 rockers
306 cam on a 112 lsa
987 springs
lloyd elliott heads w 2.00 1.55 valves
running 93 octane
Now when I had the Autolite 104's for plugs I had slight surge, but only when I babied the gas. It seems If I drive her ***** to the wall I have no surge at all
I talked with the tuner and he said he might have to up the advance a little more but to me the more advance means less power where it makes it the most. I will be trying out a few things like replacing the injectors and the regulator to make sure she gets enough petro, but that's just throwing parts at it
Old Dec 15, 2004 | 08:17 AM
T/A#4's Avatar
Why don't you go back to Autolight plugs, wondering ?
Old Dec 15, 2004 | 08:33 AM
grygst76's Avatar
I plan on it!!! Just curious why everyone praised NGK plugs when in fact IMO are garbage??
Old Dec 15, 2004 | 08:59 AM
stereomandan's Avatar
Sent you a PM.
BTW, my NGK's are working great. I didn't notice any loss in performance with them.
You might want to gap yours a little narrower like you had your autolites since you are making some serious HP. Also, are you sure non of them cracked when you installed them?
Dan
Old Dec 16, 2004 | 03:06 PM
TheBiz's Avatar
Originally Posted by grygst76
My tune is pcm4less
thunder racing MAF
no air
cai
987 springs
Thats cool. I haven't had mine on the dyno yet, and was wondering what kind of numbers I would be throwing down. I"m pretty sure we are damn near the same. Thanks.
Old Dec 16, 2004 | 06:35 PM
grygst76's Avatar
Originally Posted by stereomandan
Sent you a PM.
Dan
Good thinking on the gap issue, I did gap these at .50, I gapped the 104's at .45....something to think about
Old Dec 16, 2004 | 06:56 PM
Pasky's Avatar
Sent you a PM.
Dan
IMO, you can't ever go wrong with the general. Just stick with the delcos.
Old Dec 16, 2004 | 08:14 PM
Sorry to be off topic. This is for grygst76. One last comment about our issue:
I'm done with this. It's not worth it.
I'm not going to pursue this any further. You have done wrong, I never did receive anything.
Dan
AdsoYo
May 2, 2018 03:21 AM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
