Why do some buy non-vented optis?
I always see when people are talking prices on here that the non-vented optis cost more? Why is that? I thought the vented opti was supposed to be much better? If you can get a better vented opti for less why would anyone buy a non-vented. Sorry in advance if Im not undertstanding something here, im still learning all this =). And i apologize for another opti discussion as im sure its pretty played out. Thanks
Re: Why do some buy non-vented optis?
93 and 94 cars came from the factory with a non-vented opti. Yes, the vented opti introduced in 95 is a better design, holds up longer on average than the unvented. The problem is, you can't just take a vented opti and put it on a car that didn't originally have it without some conversion work.
I'm not sure about the price, but I assume it has to do with supply/demand.
Originally Posted by 94zgreenmachine
cams are different, at least the dowel pin length is. The timing sets and covers are different .
That's the hardest thing about doing the opti upgrade.. changing the cam..
I think you can get by with out swapping cams and only changing the dowel pin. The dowel pin drives the opti on 95 and newer(cept impala guys 94-up). Not sure how the pin would come out but it is pressed in.It may be possible.
I think you can get by with out swapping cams and only changing the dowel pin...
Originally Posted by mhhodges76
So if I have a lt4 hot cam should I gotten the vented opti.? I have had a lot of opti problems!!
ok i get it. guess from some of the threads i thought ppl were swapping the more exspensive non-vented optis onto 95+ cars and couldnt figure out why, but i just wasnt looking at the specific vehicle they were talking about. after looking through all of the threads about optis is whenever one gets posted, there are always 2 or 3 people who join in with questions because everyone so many ppl are dealing with them at all times, haha.
Originally Posted by Lower
The opti lid is interchangeable, right? So one doesn't actually have to change over the optical part, just the cap half to go to a vented setup, correct?
Courtesy of Shoebox:
http://shbox.com/1/opti_vacuum_harness.jpg
Originally Posted by Injuneer
Not really. There is also an air supply nipple on the back half of the Opti as well. The system needs the two connections, and putting them on opposite ends allows the incoming vent air to sweep the ozone out of the casing.
http://www.fierolt1.com/lt1_9394OptiRepair.htm
http://www.corvettefever.com/howto/16758/
I should have been more specific.
