No Cruise Control
Old Dec 13, 2004 | 11:48 AM
Cnadian_Camaro's Avatar
No Cruise Control
My cruise control for some reason just stopped. What should I check first?
Old Dec 13, 2004 | 02:03 PM
Joe Bellman's Avatar
Re: No Cruise Control
Check the switch on the turn signal stalk or swap it with another one. Most GM cars of the same year share the same part. I think Advance Auto or Autozone carries a generic turn signal stalk that looks the same and will work the same but costs less.
Old Dec 13, 2004 | 02:08 PM
NOMAD's Avatar
I've got tons of them. $15 shipped
-Shannon
Old Dec 13, 2004 | 02:51 PM
tintagel13's Avatar
mine is a 94 and my cruise went out when my third brake light went out...somehow the cruise and the light are connected...replaced the light and my cruise started working...
Old Dec 13, 2004 | 03:26 PM
Good idea here!
Old Dec 14, 2004 | 10:39 AM
Thanks for the reply I do have a light out but its not a brake light its a running light. Could this be it?
Old Dec 14, 2004 | 02:55 PM
anaik's Avatar
The button switch on my brake pedal lever somehow backed up and caused mine to quit. The switch is attached loose, doesn't lock down. I took off the wire connector, screwed it in a couple of turns reconnected and got it back. If you have a 6 speed, there is also a switch on the clutch pedal. Check those before you buy anything.
edman
Mar 13, 2015 09:39 PM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
