Car won't start HELP!
Old Dec 14, 2004 | 08:34 AM
Z28Screamer's Avatar
I did head/cam swap, new opti and pcm reprogram bla bla bla, ford injectors and whatever else...
car is cranking but wont start, i have spark and my fuel pressure is perfect, i dont smell fuel while trying to start though, any suggestions??
Old Dec 14, 2004 | 08:35 AM
Re: Car won't start HELP!
also i had a 1/4 tank of gas 8 months ago when i started the swap, when i turned the key on it was empty, and i refilled the gastank.. if that helps
Old Dec 14, 2004 | 07:31 PM
slopokrodrigez's Avatar
If you're sure you have spark and the fuel pressure is ok then either try a noid light or squirt fuel into the intake and see what happens. If it still won't do anything, check compression.
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
