Most RPM on stock LT1
Old Dec 11, 2004 | 02:22 PM
93LT1355's Avatar
What is the most RPM you could turn over in a stock LT1 without running into problems?
Old Dec 11, 2004 | 02:32 PM
redcamaroz28's Avatar
Re: Most RPM on stock LT1
You aren't going to make power above 6100 with the stock cam, so I'd say that's the limit. I have my shift points (fellow A4 driver here) set at 5900, 100 RPM's more than stock. There's no need to go any higher.
Old Dec 11, 2004 | 02:34 PM
SPEED750's Avatar
I think under 7000. I've heard of guys turning over7k but it eats opti's.
Old Dec 11, 2004 | 02:36 PM
93LT1355's Avatar
I understand that the cam will no longer make power after 6100 but i had a friend who had his shift points changed to 6500 (WOT) and i was just curious if he was going to run into engine problems running that high of rpm on a stock LT1 with minor bolt ons.
HectorM52
Jun 23, 2016 08:42 PM
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
