How to figure out compression ratios
Old Dec 15, 2004 | 09:47 AM
chevy1963's Avatar
Does any one know how or can explain how to figure out compression ratios?
Old Dec 15, 2004 | 10:12 AM
ShelbyZ28's Avatar
Re: How to figure out compression ratios
Its the ratio of the maximum volume to the clearance volume of the cylinder.
CR=V1/V2
V1=Maximum Volume (piston at crank dead center)
V2=Clearance Volume (piston at head dead center)
-Bryan
Old Dec 15, 2004 | 10:28 AM
chevy1963's Avatar
Thanks, but what tools can I use to determine the ratio?
Old Dec 15, 2004 | 10:51 AM
Go to the "stickies" post at the top of the forum listing, and select the one titled "Automotive Calculations on CamaroZ28.Com ". There is a compression ratio calculator there that will tell you all the info you need to do the calculation, like combustion chamber cc's, piston dish or valve relief cc's, head gasket thickness, etc.
bunker
Jan 30, 2016 08:09 PM
jbert55
Oct 31, 2015 03:52 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
13qtr
Jul 19, 2015 05:30 PM
