Wheres the cheapest place to get Lt4 valve covers and how much are they going for?
Old Dec 11, 2004 | 01:07 PM
trans9_5am's Avatar
Looking for the plastic Lt4 VC's. Also, does the alternator need to be altered inorder to run these?
Brandon
Old Dec 11, 2004 | 01:52 PM
dmoor88's Avatar
Re: Wheres the cheapest place to get Lt4 valve covers and how much are they going for?
jason cromer maybe?
Old Dec 11, 2004 | 02:23 PM
blazzinbird's Avatar
There not cheap by anymeans
Old Dec 11, 2004 | 02:40 PM
trans9_5am's Avatar
Well what is the usual going rate for them?
Brandon
Old Dec 11, 2004 | 03:43 PM
truedualws6's Avatar
This is what you will need. Not sure of the prices as I grabbed this off an
old post on the topic:
(1) LT4 VALVE COVER (DRIVER SIDE), PN 12552321, $63.60
(1) LT4 VALVE COVER (PASSENGER SIDE), PN 12552322, $68.40
(8) VALVE COVER SCREWS, PN 10108675, $0.75/each
(8) VALVE COVER STUDS, PN 10108674, $2.57/each
(1) OIL FILLER CAP, PN 12555685, $3.79
If you want to get an idea of the current price just check gmpartsdirect with
the above PNs. I find that the gmpartsdirect price (total w/shipping) is about
the same as the discount price I get from my local dealer.
Old Dec 11, 2004 | 04:50 PM
anaik's Avatar
Brandon
I paid $204 from Dal about a year ago. No alterations to the alternator required.
Old Dec 26, 2004 | 05:50 AM
MentalCaseOne's Avatar
After just one hr with my new Scorpion Roller Rockers and Beehive Springs I am fed up with the noise. They arent clacking but they are loud in general...
Question,,, I am thinking of buying the LT4 covers.. What Kind of Gasket can I use?? and what are the screws and studs for? the OEM valve covers go with long screws only.. when you mention studs and screws makes me think there are some type of modification required before the LT4 valve covers can be installed succesfully...
does anyone know?
Marvin
Old Dec 26, 2004 | 08:22 AM
You will need everything truedualws6 said.
Current pricing:
12552321 $80.85
12552322 $86.40
10108675 $0.88
10108674 $2.93
12555685 $4.20
The covers use a special gasket that should come installed on the cover, though there have been some people that have gotten covers that had no gaskets.
10108625 gasket $8.54
You may also want to add the Corvette PCV/CCV hose that goes from the throttle body to the passenger vave cover.
12557604 hose $3.39
Old Dec 26, 2004 | 02:51 PM
Current pricing:
12552321 $80.85
12552322 $86.40
10108675 $0.88
10108674 $2.93
12555685 $4.20
12557604 hose $3.39
This info is so awesome Shoebox. It may have taken me days if not weeks to gather all the part number on my own. I must tell you that your help is trully appreciated Shoebox.
Happy Holydays sir.
Marvin
Old Dec 26, 2004 | 09:48 PM
anaik's Avatar
Don't listen to Shoebox about the LT4 hose, Just cut it to length and the heat from the engine will straigten the small curve out. .
Old Dec 26, 2004 | 09:54 PM
Yeah!!! he didnt explain why I will need studs and screws either!!!
Anaik I know you right but but but.... isnt the LT4 hose prettier??
Marvin
Old Dec 26, 2004 | 10:00 PM
anaik's Avatar
[QUOTE=MentalCaseOne]Yeah!!! he didnt explain why I will need studs and screws either!!!
Marvin[/QUOTE
It is.
Old Dec 26, 2004 | 10:13 PM
anaik's Avatar
Here's picture of what they look like. I hope you don't have dial up
http://www2.hawaii.edu/~wilsonch/lt4valvecover.htm
Old Dec 26, 2004 | 10:15 PM
what picture?
Old Dec 26, 2004 | 10:19 PM
anaik's Avatar
Originally Posted by MentalCaseOne
what picture?
Opps, there it is. Go back.
