reaction to hogging out cat????
Old Feb 15, 2004 | 10:33 AM
MuffZ28's Avatar
If I hog out my cat, what will the O2 sensor do? Will it make my car run lean/rich? How hard is it to remove cat on drivers side manifold?
Old Feb 15, 2004 | 01:16 PM
S.J.S.'s Avatar
You'll have to take them to an exhaust shop and have them cut out and went in a pipe. I did that on my 97 with dual cats. It cost about 50 bucks.
As for the sensors, I think you gonna have to get the comp reprogrammed and have them deleted or you might throw a code. Im not sure about that, hopefully someone will clarify.
Old Feb 15, 2004 | 01:36 PM
tagz's Avatar
I believe that any adjustments to your cat will not cause any change in air/fuel ratio. The O2 before the cat determines that. (Later years have 02's before and after the cat )
Old Feb 15, 2004 | 01:43 PM
SlickBlack Z's Avatar
Since you have a 96 with OBD2...you will have to keep your pre-cat O2 sensors in place, and get O2 sims for the 2 post-cat sensors.
Old Feb 15, 2004 | 03:16 PM
TedH's Avatar
Probably won't do diddly for performance at your level of modifications.
Old Feb 15, 2004 | 04:52 PM
MuffZ28's Avatar
Is my car only a single cat? What's the coffee can looking thing below drivers side manifold? Should I need 1 or 2 sims? Both my cat and muffler are single inlet/outlet.What does a comp. re-prog. cost?
Old Feb 15, 2004 | 07:23 PM
eagleknight97's Avatar
You are a dual cat car. You will need 2 oxygen sims.
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
