Convertible top leaking
Old Feb 15, 2004 | 04:10 PM
metallicamaro's Avatar
hey just wondering if anyone has had a problem with their convertible top leaking on both sides right at the side windows neer the windshield. Is it the rubber seals or the top itself. I did notice that the stitching on the top in the area is coming apart, but i thought the seals should keep the water out. thanks,
-daniel
Old Feb 15, 2004 | 04:13 PM
Pandamonkey's Avatar
You many have more luck by posting again in the Lounge or Appearance or even Show and Shine section.
From what I have read - once the stitching is split, you're going to have constant trouble.
Old Feb 15, 2004 | 04:46 PM
gb95zconv's Avatar
Its the seals....pretty common problem.
Old Feb 15, 2004 | 05:04 PM
CamaroGuy22's Avatar
I noticed on mine, if i did not open the door to put the window up, there would still be a tiny crack of an opening where water would get in.
Old Feb 15, 2004 | 05:27 PM
95RagtopTA's Avatar
Mine has leaked from day one, both sides. While it was under warranty, I had the dealer try to fix it 4+ times. They ended up "reinforcing" and "adjusting" the rubber boots on each side of the windshield, but it will still leak in a driving rain. My driver's side speaker died because of water getting in . Hope you have better luck then me!
WildRidez
Feb 23, 2015 07:24 PM
nosliw
Feb 7, 2015 01:30 PM
joe777107
Dec 1, 2014 09:32 AM
squarehead
Nov 21, 2014 08:02 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
