MSD Digital 6 vs Mallory Hyfire 6
Old Feb 16, 2004 | 05:57 PM
10secz's Avatar
I'm planning to swap my Crane ignition box for either an MSD or a Mallory digital box, but I'm not sure if either one will fit here:
http://para.noid.org/~lj/1000hp/images/cranenew.jpg
The MSD looks to be 0.2" taller than the Crane, which has one small nick from the hood touching it. Another 0.2" could be fatal. And I haven't found any dimensions for the Mallory 685. Anyone have either of these boxes? Where did you put them?
Old Feb 16, 2004 | 07:18 PM
sandmanljs's Avatar
Just out of curosity what dont you like about the crane unit. I was thinking of buying one, but i have yet to find anybody with anything good about it. Thanks.
Old Feb 16, 2004 | 10:18 PM
10secz's Avatar
I have no complaints - the box has worked fine for me since 1997. But I think I fried it this weekend trying to troubleshoot a no-start problem. It blew it's fuse, and when I tried to put in a new one, I was rewarded with a bright and loud spark, so something inside the box is shorted to ground.
Since I'll likely need a replacement, I figured one of the new digital boxes with multiple rev limiters, and maybe built-in boost-referenced timing (the Mallory 685), would be a good deal. The MSD Digital 7 looks good, but it's W A Y expensive.
Old Feb 17, 2004 | 04:36 PM
sandmanljs's Avatar
THanks, I guess if it worked well for your sick car, it should be more then enough for my pretty much stocker. THanks.
Old Feb 18, 2004 | 06:34 PM
Chopstix's Avatar
your mounting location looks familier
I am running the Digital 6
http://images.cardomain.com/member_i...76_21-full.jpg
Old Feb 18, 2004 | 09:49 PM
CAsnksknr's Avatar
I've got the Digital 6. It's mounted under the driver's seat. Blaster HVC II coil is mounted on a custom plate on the lower driver's fender with a custom Super Conductor 8.5 wire for the LT-1 distributor. If you go this way, MSD will send you the coil wire pre-terminated, just state the length and connections.
Michael
Old Feb 23, 2004 | 06:31 PM
acid5868's Avatar
On the digital 6 how bad was the install, similar to the MSD 6AL? I've been debating on picking the digital 6 up for awhile now, just not sure what coil or where to mount everything at.
You wouldn't happen to have pics would you michael that I can take a look at your setup?
93 RedBird
Nov 15, 2015 08:24 AM
n2oblkz
Oct 22, 2015 02:31 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
