Is my starter going out?
Old Feb 16, 2004 | 03:17 PM
speed_demon24's Avatar
When I get in my car after its been sitting awhile and try to start it, I just get a click. But if I wait with the ignition on for a few seconds and try again, it starts right up? The battery is only a month old btw.
Old Feb 16, 2004 | 03:59 PM
First check should be that the battery cables are clean and tight.
Old Feb 16, 2004 | 04:04 PM
ead94z28's Avatar
Yea, check that red junction box and the ground stud on the passengerside fenderwell. They can get pretty nasty. I actually replaced the whole junction box. It was all corroded. As far as the stud goes, just take it out and clean it.
Old Feb 16, 2004 | 07:46 PM
Theres no corrosion on the battery terminals or anything, and its not the starter. It just takes a couple seconds for the volts to come up high enough for the starter to crank over after I turn on the ignition. Does anyone know whats causing this?
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
