Teflon?? rings on fuel injectors
Old Feb 15, 2004 | 08:34 PM
joelk's Avatar
I pulled my intake to replace gaskets/seals. When I pulled the injectors and fuel rails to replace the O Rings on the injectors I saw some O Rings above the rubber O Ring that look like they are made of teflon. What is the purpose of these teflon rings? I am guessing they just stabilize the injectors. Do they do anything else? A couple of mine are cracked. I think I can get them back in place in the intake bungs. If they are just there to stabilize I think they should work OK even if they do have a crack in them. It they do something more/else I may need to replace them
Old Feb 15, 2004 | 09:46 PM
ChevyTuffD.A.'s Avatar
I had this problem when i pulled off my fuel rail except mine broke in half. The only place i could get them was in a complete injector seal kit from a dealership and it was like 20-some dollars, i ended up takin the old ones from a friend who switched to some Accels and didnt need them.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
