fuel problem
Old Feb 16, 2004 | 03:09 PM
speedcrazy's Avatar
fuel problem
i think im on the right track with my car. im not able to do anything on my car until spring though. but i think its somethin i need to take care of right away.
basically my car seems to run richer than it should first of all.
sometimes my car will miss like a cylinder isn't firing and will be really rich. black smoke out the exhaust. the car will buck some. run really rough.
next thing i notice is that my oil smells of a little fuel. not much but even some is a problem.
also when my car is cold sitting for a while starts no problem. if i have been using my car then turn it off and go to start it 15 or 20 mins later then sometimes it cranks for a couple seconds before starting.
so im thinking that an injector could be leaking when i turn off the car and im losing the pressure and thats why it starts harder after sitting for a bit and also some gas leaking down through the cylinder into oil from injector.
do you think all the problems above could be related to a leaky injector or something else?
i guess maybe only way to tell for sure is to put a fuel pressure checker on and see if pressure drops when i turn off car?
could there be anything else leaking besides an injector?
let me know if im on the right track, thanks
Old Feb 16, 2004 | 07:06 PM
slopokrodrigez's Avatar
Yes you are on the right track.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
