People with LS1 mounts inside
Old Feb 16, 2004 | 11:25 AM
SS Mark's Avatar
How do you use the ls1 1le trans mount? It looks completely different than the LT1 stock or aftermarket mount. I have a really bad vibration problemwith my poly it is driving me nuts. It vibrates even when I am in neutral and rev it up. Any help is appreciated.
-Mark
Old Feb 16, 2004 | 12:06 PM
SS Mark's Avatar
anyone?
Old Feb 16, 2004 | 10:31 PM
Wildwill2855's Avatar
OHH HOWS THIS IDEA, MY CAR HAS THE SAME PROBLEM DUCT TAPE AND SUPER GLUE MAYBE IF YOUR RICH EPOXY IT HAHAHA AND I HAVE LT'S TOO! AND THE A-4
Sounds to me the people who get the es **** with auto's most likely hate it , where as the manuals love it? Weird
Old Feb 16, 2004 | 10:35 PM
faded93bird's Avatar
I have a poly mount and my car dosent vibrate bad.
Have your drive shaft balanced
Old Feb 16, 2004 | 10:45 PM
93Z4ME's Avatar
Got my 1LE mount from SLP and bolted right in, looked like my original but stiffer rubber, not sure why you are seeing a drastic difference.
Old Feb 16, 2004 | 10:50 PM
People on here say the ES mount is bigger i guess hight wise compaired to our stock rubber ones and that slightly raises the transmission and messes up the driveshaft? Seems reasonabe I never had the problem untill I installed hooker lt's and poped the mount and got the ES everysence then OD Vibrates I got to run around in D to keep it somewhat smooth from 1800 r's up
Old Feb 16, 2004 | 11:36 PM
SS Mark's Avatar
Apparently no one read the part where I said it vibrates in neutral also, that would eliminate the driveshaft being a problem now wouldnt it
HarleyZ28
Oct 5, 2015 06:23 AM
Jun 6, 2015 08:27 AM
rjc1629
Jan 27, 2015 10:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
