Timing Help
Old Feb 16, 2004 | 12:13 PM
93ZM6Tally's Avatar
Timing Help
I guess I'm a little confused. Going with a true roller from CM so I've got my old chain off. Took it off being careful to be at #6 TDC. Long story short I had to rotate the crank a couple of times without moving the cam, BTW my rockers are completely loose so I didn't bend anything. OK now it's time to put the new chain on. All I need to do is make sure the crank dot is straight up and the cam gear is straight down that will put me at #6 TDC right? In other words as long as the crank dot is at 12:00 O'clock I'm at number 1 and 6 TDC so I don't need to check if the number 1 piston is at the top.
Old Feb 16, 2004 | 12:41 PM
Sounds all right.
Old Feb 16, 2004 | 01:26 PM
93ZM6Tally's Avatar
Thank you sir.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
