230/236 cam.
Old Feb 16, 2004 | 07:04 PM
besz28's Avatar
230/236 cam.
hello i have a question well after my 230/236 cam install along with lloyd's heads my car around 2200 -2400rpm if your driving you sort of feel little "surging" is the only way to describe it their is no loss of power or misses is this maybe the way this cam drives? could it be my stock fuel pump(i do have 30lb injectors) maybe someone with this cam and a 6 speed could tell me if this is normal. i had my car programmed by pcmforless. thanks
Old Feb 16, 2004 | 07:06 PM
Spinner's Avatar
Cam surge. Big cams generally dont like low rpm cruising.
Old Feb 17, 2004 | 04:57 AM
besz28's Avatar
any more?
Old Feb 17, 2004 | 05:12 AM
1982z28with18s's Avatar
Talk with Bryan and see if he can program it some more. Let him know what it is doing.
Old Feb 17, 2004 | 09:43 AM
All_Z_Way's Avatar
A custom program should take care of that.
My car surged pretty bad with the XE230/236 about 1800-2000 rpms.
I received another board members custom tune and uploaded it and it has worked great.
Old Feb 17, 2004 | 02:18 PM
llafro's Avatar
I have a pretty god dyno tune on mine. It doesn't surge much at all. Usually it will surge around 1500-1800 or so. Keeping it above 2000 solves that problem. I am having problems with an exhaust leak at the collector, which seems to exacerbate the surging problem.
BRAD
Old Feb 17, 2004 | 02:23 PM
RealQuick's Avatar
SamI have a mail order which works about the same as yours (1500-1800rpm has slight surge), but iots fine after that.
Old Feb 17, 2004 | 09:11 PM
besz28's Avatar
where do i get a custom tune?isn't that what bryan did?
Old Feb 18, 2004 | 10:22 AM
All_Z_Way's Avatar
Bes.... You are correct, but maybe he needs to make some adjustments to it.
My car doesn't surge at all now.
Old Feb 18, 2004 | 11:50 PM
96LT14u2Nv's Avatar
yep that is good old cam surge. i have the same thing now that i swapped to a t-56 with that cam and 3.73's. i would suggest selling those gears and getting some 4.10s. ive done the tuning thing with no success. i wish i knew what u guys were doing
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
MDZ28
11
Sep 24, 2015 09:15 AM
xxsaint69x
Sep 26, 2002 10:23 AM
Black Sunshine/ 00SS
Sep 11, 2002 07:01 AM
ElkyRacer
Advanced Tech
Sep 3, 2002 01:27 PM
