So I have an electrical light show under the hood
Old Feb 15, 2004 | 10:43 PM
faded93bird's Avatar
Unhappy So I have an electrical light show under the hood
Ok, there are a few arcing wires this I know (and will be taking care of). There are also a few other areas of concern I would like some advice.
1. There is a tad bit of arcing in the coil between the outer ring (magnet) and the inner body. Is this normal? If not: could the arcing wires or a ground problem cause this?
2. Lots of light coming from the alternator as well mainly to the accessory bracket and the belt. Same question as the above for cause
Now if anyone could be so kind as to maybe set me up with a diagram of all, the engine ground locations it would be a great help. I had the motor out for an extended period of time and may have not put them back right.
Thanks any input would awesome and I can get a list started to begin on Wednesday.
Faded
Old Feb 15, 2004 | 10:46 PM
JDBlaze85's Avatar
fix the busted wires first of course.
when I had one wire arcing........I had a light show going on to in other places.
fixed the wire and that fixed the rest of the light show.
Old Feb 16, 2004 | 05:42 PM
442olds's Avatar
The coil arcing is normal, or at least that is what the MSD tehc told me. I changed coils because I could see the arcing your referring to on a drak night. He said that the high powered coils all do that. its nothing to worry about. My stock coil did it, and I checked several others including a freinds Mustang. So I wouldn't worry about the coil.
Old Feb 16, 2004 | 06:00 PM
442 thats what i was looking for thanks
squarehead
Jan 15, 2015 07:02 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
fpete1992
Dec 11, 2014 03:51 PM
