Rear Brake Pad Install
Old Feb 16, 2004 | 10:50 AM
AdamZ1LE28's Avatar
About to do my back brakes, do I need the tool to rotate the piston, or do I only have to compress it? I did the fronts before and only had to compress it, just wondering if I need the tool to rotate it in the back. Thanks!
Old Feb 16, 2004 | 10:53 AM
You just need to press the piston in with a c-clamp on the old pad. Note also that you can swap the rear pads simply by removing the top pin/bolt and pivoting the caliper out on the bottom pin/bolt.
Old Feb 16, 2004 | 11:55 AM
The backs are pretty much the same as the fronts as far as replacement goes.
Old Feb 16, 2004 | 08:56 PM
CamaroSS30thAnn's Avatar
im just wondering y the rear calipers have a shiot load more parts than the fronts...lol
Old Feb 16, 2004 | 08:58 PM
HBHRacing's Avatar
they really don;t.. it;s just all in the way it;s mounted as well as the provisions for the e brakes
Old Feb 16, 2004 | 08:59 PM
The parking brake is the biggest difference.
Old Feb 16, 2004 | 09:05 PM
Hyperspeed97z28's Avatar
make sure you take off the brake master cylinder cap before pressing the piston in.
Old Feb 16, 2004 | 09:06 PM
ah i c lol......i was getting my calipers powdercoated and i want to rebuild them as well and i notice many other parts jut little ones..but i undertand what u mean
Old Feb 16, 2004 | 09:39 PM
NewbieWar's Avatar
yea, advice from me, take off the ebrake before u do them...
hehe i had to hammer the caliper off the rotor, and u need a 6" c-clamp a 4" chill do but u will need to get creative.
didnt realize why it was so hard to take off until later
Chet1185
Feb 4, 2015 09:51 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
