Installation Order/Advice
Old Feb 15, 2004 | 06:13 PM
Valkyn71's Avatar
Im planning on doing a cam install over spring break. The car currently has a bad miss at all RPMs, i believe its the opti. I came to this conclustion because it had a hesitation problem last year, and i replaced the plugs, wires, and coil which seemed to clear it up. Would it be an alright idea to replace this while doing the cam install? I know people say you shouldnt do a mod if the car isnt running right, and it could complicate the problem.
While i have the front clip off, i plan on doing Headers, Cam, 1.6rrs, springs, timing chain, opti, coil and water pump.
Anyone forsee any problems doing this all at once?
i imagine i wont know the car when i drive it again
Hopefully it will be livened up a bit
Old Feb 15, 2004 | 06:59 PM
Valkyn71's Avatar
TTT Anyone?
Old Feb 15, 2004 | 07:16 PM
zmracing's Avatar
I don't see a problem doing all of those things together. However if it is not the opti and it is a sensor or something it probably will be even worse than before with headers and a cam.
Zack
Old Feb 15, 2004 | 07:33 PM
Valkyn71's Avatar
Would having a dealer read the codes tell me if it is a sensor? or verify the opti for that matter.
Old Feb 15, 2004 | 08:27 PM
Valkyn71's Avatar
ttt anyone else
Old Feb 15, 2004 | 11:10 PM
Valkyn71's Avatar
anyone ;D
Old Feb 16, 2004 | 12:39 AM
GreenDemon's Avatar
Yes, getting any codes stored would be more helpful than what you have now.
If it is the opti, then a cam and opti swap should go well together, since you've gotta rip all that stuff outta the way to do either one, might as well do them both at once.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
