How to install new dash pad?
Pretty easy . It is held on by heavy duty velcro and I believe 3 plastic posts . Just pry it up in two places with 2 wide putty knives it will pop right up. Also you will have to remove your A pillar trim .
You don't need to remove the A pillars. I had mine out a few times, and never did it. One word of advice though. Do not, under any circumstances, push in the middle of the pad with force. Mine cracked in half cause I was dumb, and didn't realize what I was doing.
True. It's proably better to remove the A pillars, but the dash pad will slide out without removing them, and will fit back in. You may have to manipulate it a little to get it back in. Just saying how I did it. If you don't mind removing the A pillars, its a better (Less chance of breaking) way.
Richardan15
May 30, 2015 08:36 AM
stockssn2o
May 25, 2015 08:54 AM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
