please enlighten me to the ECC canister
Old Feb 16, 2004 | 11:32 AM
dreamer1q's Avatar
What is its purpose, where is it located and how can I tell if it is worn out. I seen Injuneer post about that as a possible cause of running rich, and I would like to verify that it is or isnt my problem
Q
Old Feb 16, 2004 | 11:44 AM
EVAP system
It's purpose is to reduce emissions by collecting vapors from the gas tank and burning them in the engine. The charcoal canister is used to store vapors until the pcm purges them.
The only way I could see it causing a rich condition is if the purge solenoid was open when it was not supposed to be, letting vapors into the intake.
The complaints I have heard most are a gas smell when one of the hoses gets cracked/broken, comes off or installed wrong.
Old Feb 16, 2004 | 12:04 PM
Supposedly you can saturate the canister with fuel and get raw fuel in the system when the purge valve opens.
Old Feb 16, 2004 | 12:38 PM
dreamer1q's Avatar
The only reason I even considered this is when I log a run in Datamaster, I can watch the ECC scroll up to 100% and it wont drop down until I release the throttle. I never paid it any attention, figuring it was just a emissions thing anyway. But now I have a rich condition I have been chasing for awhile, and Freds post rang a bell. Is the ECC suspose to run up to 100% and stay there till the throttle is released?
Thanks for the quick answers guys, I appreicate it.
Q
Old Feb 16, 2004 | 12:47 PM
It purges quite a lot of the time when the engine is warm and the throttle is open.
Old Feb 16, 2004 | 01:02 PM
ead94z28's Avatar
So it's not worth replacing a saturated cannister, as long as the fumes don't bother you? Just wondering if emissions testing would be affected.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
MDZ28
11
Sep 24, 2015 09:15 AM
MDZ28
Sep 7, 2015 09:16 PM
350350
14
Aug 11, 2015 12:03 PM
