Fuel pressure woes...help!
Old May 27, 2003 | 10:32 AM
BAD 97 WS-6's Avatar
I have been noticing low fuel pressure for the past few weeks. I changed my fuel filter about 2 weeks ago and nothing has changed. With the car running and the vacuum removed from the regulator, I only get 37-38 psi. I get the same psi at WOT with the vacuum hooked back up. I know 41-43 is normal. What do you think it is?
Old May 27, 2003 | 08:59 PM
anyone?
Old May 27, 2003 | 09:14 PM
96z's Avatar
96z
Fuel pump possibly? Bad regulator?
Old May 27, 2003 | 10:46 PM
94FlamdS10Blazr's Avatar
try to hook up a clean vac hose to the line going into the regulator and sniff to see if you smell gas. If you do its toast cuz the diaphragm is gone. You also might wanna pull it off to see if its clogged like mine was. Have you done the filter lately?
Old May 27, 2003 | 10:57 PM
While it may not be "optimal", the pressure should be enough to get you by for a while. You might have a decrease in performance at WOT if the pressure is not enough. Some O2 readings at WOT might give a clue. I guess the regulator is a possibility (though, I have my doubts) and is sure easier to change than a pump.
Old May 28, 2003 | 10:16 AM
Yeah, I did the filter a couple weeks ago.
If the regulator was bad, wouldnt the pressure be reading too high because the diaphragm would not be able to pull the pressure down during normal driving?
Old May 28, 2003 | 10:33 AM
Gripenfelter's Avatar
When you turn the key to the On position but not start, does the fuel pressure go to 43psi and then when you start it does it drop?
If not its a bad regulator.
A bad fuel pump would cause the fuel psi to continue to decrease.
Old May 28, 2003 | 10:37 AM
With just the key on, the pressure is at about 37-37, then when its starts, it drops to about 33
Old May 28, 2003 | 11:08 AM
just for a refence mine starts at 42 at prime and goes to about 38 running and after it gets hot it goes to about 33
Old May 28, 2003 | 02:03 PM
Another thing.
When I get gas, when I take the gas cap off, I never hear the pressure releasing hissing.
Old May 28, 2003 | 02:25 PM
JSK333's Avatar
Interesting.
Mine goes to ~36.5 at prime, stays around there while running at idle, and goes to ~43.5 at WOT.
You might have a vacuum leak somewhere on the intake manifold. Check all the lines.
Old May 28, 2003 | 03:00 PM
SweetZRag's Avatar
Look for a little puff of black smoke when the car first starts after sitting. This indicates a rich condition caused by fuel poolingi n the intake manifold. It happens when a pinhole forms in the regualtor diaphram allowing fuel to pass through the vacuum line into the intake manifold.
Also, follow the procedure in the GM manuals. It is very good at isolating the cause. It basically allos you to isolate the 3 parts of the system to determine where the pressure leak is. I have had the the regulator go and the check valve in the fuel pump at two different times. Pray it is the regulator.
Old May 28, 2003 | 03:15 PM
So your regulator is healthy.
I can't think of any obstruction that you would have in the fuel rails.
Probably the fuel pump.
Save yourself some time and get a Walbro from Racetronix.
Old May 28, 2003 | 05:25 PM
thats ok in the last month Ive had to replace the factory pump, 2 stock replacement pumps and finally dropped in a Walbro from Holley. Also did a set of 8 19 pound injectors cuz mine were clogged and a set of 24 pounders from Brian and then a regulator. So the good luck genie is one my side
Old May 31, 2003 | 06:11 PM
Problem fixed. Iput a mechanical gauge at the schrader valve and come to find out my crap sending unit for my digital gauge is crap. Whew, that saved some dough.
Thanx for your help.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
