NEED HELP. Radaitor problems AGAIN
Old May 27, 2003 | 12:19 PM
LT1CST's Avatar
OK heres the Deal
94 LT1 Camaro. im sure you people have seen me before LOL
Yesterday Just flushed out the radaitor. The Heater COre TOOK a dump We replaced that. Proir to all this repairs the heator core dump FLuid ALL in my passanger floorboard. NOw for some reason. After the flush my Car is still runnning hot. IT has a Hpyertech 160 THermo. NOw. theres TWO lines that RUN from the Radiator to the THERMO. and the BLOCK I believe. They have Screws on them to open and close. The THermo screw HAs fliud going through IT no problem. The Hose that leads the BLOCK> As nothing BUT HOT air. NO FLuid what so ever. whats my problem? We Completly Drianed the Radiator and put more in and its still Bubbling that nasty Beige Brownish Color. NEED help. Whats going ON??
Chris
Old May 27, 2003 | 01:58 PM
LT1CST's Avatar
ttt
Old May 27, 2003 | 02:18 PM
rckrzy1's Avatar
you need to PURGE the AIR from the sytem through the bleeders. Open them up , then fill radiator till anti freeze comes out them.
Then run and cool down and do again.
Old May 27, 2003 | 02:36 PM
LT1CST's Avatar
Ok no problem. But I have another question. Y is my fluid color still beige in color. and the over flow cap is still over flowing. ALSO. SHould the car be running when I purge the system? thanks
im at work
Chris
ttt
Old May 27, 2003 | 02:41 PM
If the coolant is not the correct color, you did not get it flushed or you may have cross contamination from the oil system from a head gasket or crack somewhere. That could also be where your excess air is coming from. Check the oil level and it's color, too.
Old May 27, 2003 | 02:47 PM
LT1CST's Avatar
Hey SHoe. The head gaskets could that be also Y SOMTIMES my Car idles RUFF. like it wants to die out. But when I get on it it flies? Sounds like its time for a new motor. LOL I need to bandade this thing is much as I can at least for a while. Thanks
CHris
TTT
Old May 27, 2003 | 03:09 PM
LT1CST's Avatar
hey shoe also. Proir to all of this happing. When ever I would turn the AC on there was smoke coming from the VENTS so what ever that means.
TTT
Old May 27, 2003 | 06:44 PM
LT1CST's Avatar
Hey guys well I talk to a local radiator shop. And they seem to think that all I have is AIR in the system. He said that Its pretty common that the LT1's take a while to bleed all the air. SO Ill try that and im sure IF i have anymore problems ILL let you guys know about it.
CHris
ttt
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
beltrunner
Apr 15, 2015 01:10 AM
DetroitZ28
Feb 13, 2015 07:33 AM
CAJUN-Z
Jun 20, 2002 08:56 AM
