Degrading Gears
Old May 27, 2003 | 02:28 PM
WheelmanZ28's Avatar
Degrading Gears
I recently picked up a ***** set of 3.73 gears for my car. No matter how many times i had the rear end apart, it would not be able to be shimmed out enough so that it would STOP ******* WHINING. I had the gears professionally done a number of times, and still nothing. The gears ARE VERY LOUD. I'm worried that this is causing me to have a weak rearend. I'm afraid to go with N20 off the line cuz i dont want to blow the rear end.
I also can't stand driving with these gears on the highway. When I'm going 80 MPH i feel like I'm killing my motor by staying at such High RPMs for so long.
So I'm thinking of stepping down to a 3.42 gear. Hopefully this will give me better gas mileage, better traction, quieter, and stronger out of the hole. So let me know what u all think. Worth stepping down? Stronger gears? Any help on the subject would be appreciated. (BTW i have a 3 series torsen diff carrier) THANX
Old May 27, 2003 | 02:52 PM
norcalstreet's Avatar
Camaro rearend gears are known to whine. Motive/GM gears are known to whine the least and I used to run some Precision Gears in my car that never whined. My current 3.73 Strange gears do whine quite a bit but they've been running strong for about a year now. I would suggest changing brands before stepping down to a lower gear. The higher the gear ratio the stronger it is.
Old May 27, 2003 | 03:03 PM
Are u sure about that?
When u go up in gear ratio, u are lowering the number of teeth on the pinion gear, and thus less teeth make contact with the main gear. Wouldn't this mean u have more of a chance breaking a gear if less teeth are in contact with the main gear? especially if u launch hard. I know a lot of people who run 4.10s in their automatic and blow them like crazy.
Old May 28, 2003 | 02:54 PM
TTT
Old May 28, 2003 | 04:32 PM
A 3.73 is a higher ratio than a 4.10. Seems kind of backwards, I know. When I refer to a higher ratio gear set being srtonger it's because it has less teeth. This results in the teeth being thicker and thusly stronger. It may vary from brand to brand. I have heard that Strange gear teeth are a little stronger than, say, Motive. Don't quote me on that though.
Old May 28, 2003 | 05:31 PM
Well, I've decided for sure that I'm gonna step down to 3.42 gears. My programming currently sux as well, so i'm gonna get a PCMforless tuning while I'm changing gears.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
