EGR questions
Old May 28, 2003 | 01:33 PM
AENIMA95z28's Avatar
EGR questions
I heard it can be bad for your engine to remove the EGR system. Is this just b.s. becuase i thought the EGR was just for emissions. What exactly does the egr do?
Old May 28, 2003 | 01:43 PM
EGR is used to reduce the formation of oxides of nitrogen (NOx), a pollutant. It accomplishes this by quenching (reducing) combustion chamber temperatures under certain part load conditions, like "lugging" the engine at low rpm in the wrong gear. Under these conditions, the EGR recirculation will also reduce the tendancy to detonate.
It never operates at full load/WOT, so it has no impact on performance.
Old May 28, 2003 | 01:44 PM
chasmanz28's Avatar
Re: EGR questions
The EGR re-routes some of the exhaust gases back into the intake/combustion chamber. This is basically done to reduce emissions. Blocking it off will reduce the temperature of the intake since the gases fed back through the EGR are very hot. Lower intake temperature produces more power, but the amount of gases that are passed through the EGR is VERY minimal and probably won't result in much (if any) performance gain. The drawback is increased emissions.
Old May 28, 2003 | 01:47 PM
ok cool i got it now, thanks guys
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
