Fans?
Old May 28, 2003 | 05:16 PM
Johnnynsac's Avatar
Fans?
My fans are not turning on at all when the car heats up. The only way they turn on and cool the car down is when I turn on the heater. Do you guys know what's going on?
Johnny
Old May 28, 2003 | 05:33 PM
The heater should not cause the fans to come on. Anything that triggers the a/c compressor should, though. Here is some info on the cooling system that might help.
[edit]Sorry, that link is damaged right now. I will fix it when the server lets me.
[edit] link fixed
Old May 28, 2003 | 07:26 PM
jeff1586's Avatar
i thought the same thing for a while but then i found out gm designed the fans to come on real hot, buy a fan switch and your problem will be solved
Old May 28, 2003 | 08:29 PM
Johnnynsac's Avatar
My mistake. I have to trigger my a/c compressor for the for the fans to come on, because if I don't, the fans never come on and my car starts to over heat. I Almost hit the red mark once. They use to come on all the time. I checked all the wiring and it looks fine. I'm stumped. Anyone else have this problem
Jeff, I was thinking the same thing and waited and waited for them to come on but never did. I had to run to turn the a/c compressor on for the fans to come on because the LT1 was getting way to hot.
The way I see it is, they do work but I have to trigger it.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
