ac delete
Old May 27, 2003 | 12:50 PM
FLIPPINZ28's Avatar
ac delete
i am deleting my ac and need to know what all i have to do about taking the compressor off will i just need a shorter belt or what i already have the engine out of the car because it is in the process of getting rebuilt also will my computer through up any codes because i discounected all the ac stuff i even removed the box like thing on the passenger side and put sheet metal over the whole thanks for any help
Old May 27, 2003 | 12:51 PM
FLIPPINZ28's Avatar
also cruise control i took it off as well will it hurt anything if i cut the harness off that used to plug into the cruise control also can i cut the harness that plugs for the ac
Old May 27, 2003 | 12:56 PM
You pull the compressor off, and replace it with a "1LE A/C delete pulley", about $25-30 from a discount GM parts dealer. The pulley is on a bracket that bolts in place of the compressor, and allows you to get by with a belt very similar to the stock length, stock routing
The AC delete will show up when you scan the PCM.... I believe its for loss of the A/C pressure switch, or something like that, but it doesn't turn on the SES light.
Why cut the harness connector off? Just tape it up, push it out of sight. Unless you are after max weight reduction, and never plan to reinstall any of the deleted parts. In that case, remove as much of the wiring as you can, along with the connector.
Old May 27, 2003 | 01:12 PM
FLIPPINZ28's Avatar
thanks alot for all the info it was of alot of help
Old May 27, 2003 | 11:56 PM
FLIPPINZ28's Avatar
does anybody know where i could get an ac delete pulley also couldnt i just get a shorter belt instead of a ac delete pulley and get rid of the belt tensioner and use the alternator as the tensionenr by prying it up to the bolt holes that would tighten the belts right? just have the power steerring pump and the alternator and harmonic balancer hooked up to the belt
Old May 28, 2003 | 12:33 AM
GM discount parts are cheapest from one of these guys:
Dal Slabaugh at Van DeVere Olds
lockitup@bright.net
800-362-9494
Jason Cromer at Sam Taylor Buick/Cadillac
staylorservice@cybertron.com
877-726-8295
As far as trying to drive the alternator and PS pump direct with a non-tensioned belt, you need to go look at the front of the engine and you'll see why it won't work. The damper/pulley and the alternator use the ribbed side of the belt, the PS pump uses the "back" side. The tensioner is required to keep the belt in contact with all of the pieces. Remove the A/C without the delete pulley and the tensioner doesn't work, remove the tensioner and nothing will line up (water pump is in the way) and there is no way to wrap the ribbed side of the belt, or a smooth belt around the damper the PS pump and the alternator.... it is physically impossible because three pieces are almost in a straight line, not in a triangle. And there are no slotted holes in the alternator mount to allow you to pry it.
Old May 28, 2003 | 02:17 AM
FLIPPINZ28's Avatar
thanks for that info see my engine is in pieces and i was just trying to see it in my head i will contact them for the ac delete pulley thanks again
stylin99
Feb 3, 2016 02:24 PM
tnmotown
Aug 10, 2015 11:52 PM
guest74777
Mar 25, 2015 10:30 AM
alex5366
Mar 8, 2015 11:32 AM
NVMYTA
Nov 23, 2002 06:04 PM
