93 z Help!!!!!!!!!!!!!!!!!!
Old May 27, 2003 | 05:28 PM
shootcallerz28's Avatar
I have a set of headers i will be puting on but they are for a 94,95 z i heard that 0n a 93 z you will not have to have egr and air pump edit from the computer can some one tell me something thanks
Old May 28, 2003 | 01:42 AM
JKDZ28's Avatar
No i didnt have to have it edited
Old May 28, 2003 | 02:08 AM
93TAWicked1's Avatar
There will be a tubing in the back of the pass side header you might as well cut off and have welded, the rest of the egr\air tubes should work or need mild custom to setup. If you just plan on plugging it up then no you need no custom programming
Old May 28, 2003 | 02:10 AM
GeneralZ's Avatar
From my understanding, if you are using 94+ headers on a 93, you can use the emissions hookups with no problems. But 93's only have emssions on one side unlike 94-95, so you have to block off the emissons on the other side.
someone correct me if i'm wrong
