Quickie on Shiftlight wire
Old May 27, 2003 | 07:05 PM
thewinner's Avatar
I can just hook the tach input to the white wire coming from the gauge cluster correct? as that is the tach wire coming from the pcm?
Old May 27, 2003 | 08:10 PM
12SCNDZ's Avatar
That's how I wired my Autometer shift lite.
Frank
Old May 27, 2003 | 10:21 PM
thewinner's Avatar
well ****, i got the white wire and its not working. i wiretapped the white wire using a red wire tap.....
the light does have ground and power though b/c it will let me set it up, just wont flash at the rpm level.
i set it at 2100 rpms and revved to 3500 and it didnt do anything.
Old May 27, 2003 | 10:57 PM
Blue89Bird's Avatar
use the white wire on the red connector comming out of the pcm
Old May 27, 2003 | 11:02 PM
There is more than one white wire going to the cluster. You need the one in cavity "D5". Same wire that is in cavity "D" of C230 (and pin 13 of the pcm red connector).
Old May 27, 2003 | 11:15 PM
thewinner's Avatar
you are a god shoebox. i didnt use that wire cause it looked more cream than white. what does the other white wire do? just curious
got it working, shoebox
Old May 27, 2003 | 11:27 PM
The other one is for the skip-shift. That would be ironic for your shift light to coincide with the skip-shift light.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
