Question for '93 F-cars using PCMFORLESS...
Old May 28, 2003 | 01:57 PM
FuryZ28's Avatar
Question Question for '93 F-cars using PCMFORLESS...
Has anyone with a '93 F-body (6-speed or Auto) had a chip burned by Alvin?
Old May 28, 2003 | 02:36 PM
allmotorta's Avatar
Yes.
Old May 28, 2003 | 03:34 PM
Fastbird93's Avatar
Yup, and was very pleased with it.
Old May 28, 2003 | 03:35 PM
KCFormula's Avatar
Shawn- I hear only good things about Alvin. And secondly I saw that you were looking for a timing chain. ... well the LT4 chain requires a vented optispark which also requires a different cam dowel pin. However if you look in summit there is a Lunati chain for pre vented opti cars that is a pretty good deal from what I hear. Also try this board for more SD info. Speed density messageboard
Old May 28, 2003 | 04:43 PM
speedmiser's Avatar
I spoke with Lunati and Summit about that chain. Lunati rep didnt know if it was a roller chain or not (they must let the Janitors answer the tech line). Summit said it wasnt a roller. I tend to agree with Summit. Every description I read says "Linkbelt Chain" instead of roller.
Do you know of someone who's actually used that chain, and can vouch for it? While the stock chain does stretch over time, its a pretty durable piece. I'd hate to go aftermarket only to get a weaker chain that would stretch just as much or more.
Old May 28, 2003 | 05:10 PM
FuryZ28's Avatar
so does this mean unless I wanna spend the $$ to convert my opti (which I just recently replaced...) or run an electric WP, I'm stuck with the stock LT1 timing set??
Old May 28, 2003 | 05:16 PM
Fastbird93's Avatar
I can't remember who it is, but someone did just start making a pre-vented opti timing chain set for more heavy duty applications.
Old May 28, 2003 | 05:23 PM
FuryZ28's Avatar
Well if you do manage to remember...lemme know!!
Old May 29, 2003 | 06:33 AM
IDOXLR8's Avatar
The people at PCMforless are very knowledgeable.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
ProudPony
Aug 29, 2002 04:20 PM
