blower/CR questions...
Old May 28, 2003 | 01:11 AM
WS6pete's Avatar
have a couple questions..
I know that boost and lt1's dont mix..but say i was to buy a set of forged pistons to lower my CR to say..9:1 or 9:5 or whatever... , would the lt1 hold up with say....8#'s of boost? or are lt1's not good with boost for other reasons?
and what other ways are there to lower my compression ratio besides pistons? im looking into a supercharger setup but am curious to something like this..maybe ceramic coating the pistons too?
Old May 28, 2003 | 04:59 AM
2MCHPSI's Avatar
LT1 pistons are very weak under boost conditions. It will not last long with the stock pistons, and anything over 6 psi can equal to rebuild in the near future.
If built right , LT1s can handle a ton of boost. My friend did ceramic coat his heads, intake and pistons on his blown setup. I hear it does help reducr the heat.
You can try and reduce the compression by playing witht he gead gaskets and heads, but I am not sure how much you can reduce the CR. There was a post a month or two back in the Forced induction forum. Do a search there.
blkWidow
Apr 20, 2015 09:27 AM
fesgali
Jan 26, 2005 12:56 PM
Donohue96M6Z28
Nov 17, 2004 06:09 PM
Type_O_Negative_1320
Mar 4, 2004 10:31 PM
ryan2
Feb 21, 2003 01:03 PM
