Fuel Pump Install
Old May 27, 2003 | 12:08 PM
Gripenfelter's Avatar
Fuel Pump Install
I'm thinking about doing the fuel access panel mod.
My stock pump is starting to give out by 5000rpm. Drops from 48psi to 40 psi!! Bought a Walbro.
When I cut the fuel access panel, will I be able to diconnect all the lines right there or do I still have to drop the tank or what?
Old May 27, 2003 | 12:49 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Fuel Pump Install
no need to drop pan after u use the access pannel
Old May 27, 2003 | 12:57 PM
93transam1234's Avatar
here u go
I got this link from someone else. I am plannig on doing the same thing in sbout 3 weeks so let me know how u do!
http://www.taekwondoplus.org/z28/fuelpump.html
Old May 27, 2003 | 03:28 PM
Thanx I borrowed a friend's digital camera so I'll probably make a tech page on how to install Walbros.
Old May 27, 2003 | 05:16 PM
EvlViln's Avatar
Protools4@aol.com
Contact him, he has a video of us doing mine!
Old May 30, 2003 | 03:30 PM
94droptopz's Avatar
is possible to do in a convertable? i cut the access door as far back as i could but i cant get to the fuel lines to unhook them. my convertable doesnt seem to have as much room as a coupe and i have a big brase bar right behind the rear seat.
Old May 30, 2003 | 04:18 PM
You can't cut the panel back far enough? Or is it not wide enough?
I don't think you can do the trap door on the convertibles. My friend has one and his trunk doesn't go back that far.
Unless you removed the top?
Old May 30, 2003 | 08:43 PM
94droptopz's Avatar
thats the problem i ran into, there wasnt enough room to go back and unhook the fuel lines oh well i guess i'll fix the access door and drop the tank.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
