Best way to do exhaust
Old May 29, 2003 | 07:12 AM
Newbie97's Avatar
I have a flowmaster now with stock exhaust and was wandering what could I do to get more out of the system. I read that people are going to a dual setup and I cant see how that is going to happen under an F body(not enough room). So should I go with something custom or is the stock setup good enough with shorties and a flowmaster?
Only plans I have on doing with the car right now is obd1 conversion, hedders and exhaust since this is my daily driver.
Old May 29, 2003 | 07:22 AM
Greed4Speed's Avatar
You could run a larger single pipe that is mandrel bent. Duals are a waste of money (and twice the weight of a single pipe system) unless you are really going to mod. Even running a larger single mandrel bent pipe may only gain a max of 2/10 of a second over your current setup. Usually the bend over the axel is the worse restriction in the piping. You could always put in a cut out.
Old May 29, 2003 | 08:11 AM
Lost's Avatar
You could throw on a cutout.. most people do that and like the way it sounds and it adds a little something at the track.
With that said I run hooker longtubes into two three inch pipes with and x and use no mufflers.. just collector inserts. and the rear of the car, just before the rear wheels I have it turned outward and downward. It's really not so loud
I guess you have to think of it this way, what's the best setup for me? What are my plans for the car? Do I want something custom? Something loud or something tame?
There are a lot of aftermarket bolton exhaust systems available too.. you really have quite a selection in that department. I will say that I wouldn't have anything custom made because it'll cost an insane amount of $$$ unless of course you know how to weld and can do it yourself
Old May 29, 2003 | 08:22 AM
ksmyss's Avatar
with my true dual setup and obd I conversion i picked up 4 mph in the quarter
Old May 29, 2003 | 10:32 AM
Newbie97's Avatar
Got pics of the dual setup? I want to go longtubes and a single pipe to the rear. Anyone with this setup?
Old May 29, 2003 | 12:05 PM
ksmyss's Avatar
http://web.camaross.com/forums/showt...hreadid=125831
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
