msd 6a question
Old Sep 22, 2004 | 08:44 AM
key3's Avatar
msd 6a question
ok fellas I am going to try to explain this the best I can. My brother has a 93 Z28 with a msd 6a box with the GM wiring harness. I have a 94 Z28 and took his msd box off to try it out on mine but I cant get it to work. I think the problem is in the clips that connect to the coil. I looked at his clips and the gray clip has a red with black stripe and white with black stripe. The black clip has a white and red wire going to it. Ok my car the gray clip has a red with black stripe and a white with black stripe. The black clip only has a red wire going to it. There is no place for the white wire to go so it must have come from the factory like that. I would like to try one out before I buy one but I am lost on this one. If any body could help me out on this one I sure would appreciate it.
thanks
Josh
Old Sep 24, 2004 | 09:08 AM
key3's Avatar
Re: msd 6a question
anybody, please help I would like to try to install it this weekend
Old Sep 24, 2004 | 11:42 AM
aaron_depue's Avatar
Re: msd 6a question
Im not sure man. I bought a 6a box. I ordered from jegs and told them my make and model (94 too), but I havnt installed yet. I hope that I dont have the same problem that you are. Also, are you runnin a factory coil? Was wanting some info on coil, because I was thinking about going wiht the blaster coil and need the pros and cons over facory
Old Sep 24, 2004 | 07:48 PM
key3's Avatar
Re: msd 6a question
yeah I have the blaster coil. I am just confused about how it hooks up. I am going over a friends house in the morning and see if he knows how. Its a used box so I dont have the instructions.
thanks
josh
Old Sep 24, 2004 | 10:24 PM
Re: msd 6a question
You can find instructions on the MSD website. I don't see how it should be any different from 93-95.
Old Sep 24, 2004 | 10:51 PM
97WS6SCharged's Avatar
Re: msd 6a question
Hmm... two MSD questions in one day. Anyways, this should help a bit. Just ignore the BTM stuff.
http://web.camaross.com/forums/showthread.php?t=303960
RUENUF
May 25, 2016 08:10 PM
mr28
Apr 20, 2016 05:44 PM
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
mr28
Nov 23, 2014 11:11 AM
