Scanmaster: DTC Codes 18, 36, 46, 51
Old Sep 16, 2004 | 10:25 PM
ucnu112's Avatar
Tonight on my way home from work, my scanmaster was throwing the following codes:
18 Injector circuit(s)
36 Distributor ignition system (faulty high resolution pulse or extra low resolution pulse detected)
46 Pass-Key®II circuit
51 EEPROM programming error
Any thoughts?
Fred
Old Sep 17, 2004 | 04:53 AM
slopokrodrigez's Avatar
Re: Scanmaster: DTC Codes 18, 36, 46, 51
Diodes in the alternator are breaking down allowing AC on the supply line. Measure from the negative terminal of the battery to the output post of the alternator with the meter set to AC. If they are bad, the reading will be 0.03 VAC or higher. This leaking AC will cause any PCM to go nuts and do all sorts of things. If you change the alternator, unless you changed the belt and idler tensioner recently, change them too.
Bad power or ground connections would do it also but there are several of each on the PCM and I doubt that is the problem. You should however check all the connections at the battery and the frame and the engine. Remove them, look at the contact points and shine up both the connector and the mounting point.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
timmy39120
May 8, 2015 11:41 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
