high rpm stumble (jerk)
Old Sep 17, 2004 | 10:15 AM
Deenasty's Avatar
When I drive my car, right about 5700-5800 I get one hard jerk, like stumble. it is not the rev limiter, the rev limiter is set to 6400. What could this be? Car has new plugs, wires, msd digital 6 ignition. Perhaps bad coil?
Old Sep 17, 2004 | 11:15 AM
fesgali's Avatar
Re: high rpm stumble (jerk)
I've got teh same prob and can't figure it out. I know i have alot of arching so when i get some time i'm gonna solve that prob and go from there.
I'd just start with the plugs, wires, filters, etc. and see where it leads ya.
Old Sep 17, 2004 | 11:17 AM
96lt1TA's Avatar
i had the same problem, it was exactly as you described it. i put in an LT4 knock module and with 5 mins the problem was completly gone. hope this helps
Old Sep 17, 2004 | 12:04 PM
Deenasty's Avatar
Yea like I said, the car has new plugs and wires...The car also has an lt4 km. I wonder if it could be knock or false knock causing the computer to pull timing...I might want to scan it...
Old Sep 17, 2004 | 01:05 PM
ponchoV8's Avatar
I have the same type of thing, but it's a series of light, annoying hesitation from about 5500-up. As far as I know my 120K mile car's Opti is original, so that may be it. I changed the wires with new factory ones and installed Bosch +4 plugs at 75K, but it's pretty recent my car started doing this. I posted a thread about this last nite and my 1 response was to replace my plugs because they are supposedly not that good with mileage, so I may try some NGK TR55's.
Old Sep 17, 2004 | 02:03 PM
Deenasty's Avatar
car also has new opti...
Old Sep 17, 2004 | 03:58 PM
ScreamnChicken's Avatar
check to make sure the plug wires are all the way on the terminals at the opti. I had a similar problem which I described in a thread a few pages back and that is what it turned out to be. Luckily I already had a new opti waiting because the terminals were all corroded.
Old Sep 17, 2004 | 05:35 PM
FormulaLT-1's Avatar
it could very well just be a arching issue, did you replace the coil wire?
blac94Z
19
May 13, 2015 04:50 PM
warmeck
May 7, 2015 02:10 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
PhantomTA
Aug 17, 2002 12:19 AM
