Going for 385CI with CC306, What is expected HP/TQ?
Old Sep 18, 2004 | 01:37 AM
BlueCamaroZ28's Avatar
I am going to build a 385 LT1 stroker motor NA, all eagle forged parts. Will use JE 16cc dish pistons.
I have TPiS LT1 heads, 54cc. I will put a cc306 camshaft. Has 52mm BBK TB and comp cam 1.52 rocker arms. Will use 30Ib/hr FMS injectors and stock LT fuel pump. I am using long tube headers.
How much HP/TQ could I expect from this combination.
Old Sep 18, 2004 | 09:52 PM
simple's Avatar
Re: Going for 385CI with CC306, What is expected HP/TQ?
you arent going to be doing much better then most of the stock bottom end head and cam cars, that cam (306) is tame in a stroker
IMO, buck up and spend money on a custom grind that has more potential
otherwise i'd bet down the road you will want more. specially after getting whooped on by stock bottom end cars
Old Sep 19, 2004 | 10:22 AM
got_hp?'s Avatar
even if you dont get a bigger cam, you definetly need bigger injectors and bigger fuel pump to be safe and reliable.
Old Sep 20, 2004 | 04:26 PM
I heared the stock fuel pump is good for 400RWHP. Is it possible to raise the fuel pressure of the stock pump using adjustable FPR or that's the limit of the stock pump 43 psi.
Old Sep 23, 2004 | 04:56 PM
Ttt.
Old Sep 23, 2004 | 04:58 PM
WS Sick's Avatar
A strong stock pump will work, but with the potential a 255 lph would be the safe bet.
2QUIK6
Sep 17, 2016 02:31 PM
drt
Sep 27, 2015 04:39 PM
Z Power
Sep 19, 2015 11:19 PM
WPHIG2
Aug 27, 2015 06:37 AM
nd4spd200
Aug 21, 2015 09:30 AM
