Hopefully my final VATS question. :)
Old Sep 16, 2004 | 09:04 PM
95LT1Z28's Avatar
Okay, I just bought a '96 Z28 and it has been setting the code 1626 anti-theft system fuel enable circuit. The car will start and run good, but only after a lot of cranks . I look under the dash to find my orange tubing with the two VATS wires in it. When I take the reading from the dash side connector (end going to BCM) and my multimeter set on 20K, it reads -10.43. What is up with it reading negative??? To enhance my problem, the BCM is not the original. The previous just grabbed another BCM from a wrecked car. How can I read what value the other BCM's resistance code is at? Or do I need to go out and buy a lot of resistor's at Radio Shack and test until one combination works? Thanks for any help!
Jeff
Old Sep 16, 2004 | 10:17 PM
Re: Hopefully my final VATS question. :)
I don't think you can tell anything when taking a reading toward the BCM.
magman
Apr 15, 2016 03:08 AM
colts0455
Oct 4, 2015 09:47 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
colts0455
Sep 27, 2015 01:07 PM
