Powdercoating block after assembly?
Old Sep 17, 2004 | 12:39 AM
RacerTim's Avatar
Is it ok to powdercoat the block after it has been assembled? Will high temp be strong enough to take the heat?
Old Sep 17, 2004 | 02:22 AM
RE AND CHERYL's Avatar
Re: Powdercoating block after assembly?
You can't powder coat it after the engine has been assembled. You can however just use automotive based paint. I used Dupont base/clear on the 400 in my 69 and years later it looked perfect with only a little bit of flaking around the exhaust ports.
Fastbird93
Apr 9, 2016 07:01 PM
Sergio
Jan 27, 2016 04:27 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
