Huge leak after oil change.....
Old Sep 19, 2004 | 07:32 PM
Kurt Crosbie's Avatar
I changed my oil a few minutes ago and put a new oil filter on. After completion, I cranked her up and I noticed a puddle of fluid developing under my car at a rapid rate. It looked like it was coming from up around the oil filter area.
*It only leaks when its running. I'm not kidding. Not one drop when its off. And when it does leak, it comes out extremely fast. It's like a 1-inch diameter stream of fluid. I'm 99% sure its oil.
Old Sep 19, 2004 | 07:37 PM
TQdrivenws6's Avatar
Re: Huge leak after oil change.....
Did you make sure that the gasket didn't stick to the block and you just put the new filter on? If you have two gaskets on there it would lead to that.
Old Sep 19, 2004 | 07:38 PM
Robert95z's Avatar
Probably a double oil filter gasket, check your old oil filter, is the gasket on it? If not remove your new oil filter and make sure there is only one gasket,
Old Sep 19, 2004 | 08:49 PM
LT1Squirrel's Avatar
123
Old Sep 19, 2004 | 08:54 PM
speed76demon's Avatar
1234
Everytime I change my oil that gasket stays on, but I always make sure to take it off
Old Sep 19, 2004 | 08:55 PM
Getsome17's Avatar
Have fun cleaning it up I know I did.
Old Sep 19, 2004 | 11:28 PM
There has been a very aggrivating end to this story. It turned out to be a PH25 filter in a PH30 box... Some ******* must have been switching them around. Anyway, no stuck gasket. It just crossed my mind, so I went and looked at the filter number on the actual filter. Sure enough...
rideordie
Nov 5, 2019 04:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
alex5366
Feb 17, 2015 10:43 PM
