what psi for ET streets
i bough ta set of et street 26 10.5 16. but im wondering what yall are running in as far as air pressure. i figured somwhere between 24 and 18. but what has worked for yall.
oh and does anyone have a 9" they would like to donate to a
caritable cause.
caritable cause.
Re: what psi for ET streets
You might want to try the Drag Race forum, but I'll help you out anyway.
ET streets like a lower pressure. 18-24psi is better suited for a drag radial, not a drag tire.
I found I hooked best with pressure at 14psi.
Keep in mind, chances are you're going to break something with ET streets, especially if you're an M6 and you launch hard.
What you want to do is run the highest air pressure that you can with still being able to hook. Obviously this all depends on your car setup. I started at 15psi and worked up to about 17psi being best. Just a small burnout was all I needed and even then, when I dumped the clutch at 4000rpm the car bogged down.
Aaron
Aaron
Louey
Pacific
Aug 7, 2015 01:47 AM
Louey
Pacific
Jul 21, 2015 10:06 PM
