Overheating problems with 96' T/A
Old Sep 19, 2004 | 12:32 AM
WheelsupChad's Avatar
Drive it down the road and water overflows out of the recovery tank. It has a 16pd radiator cap and the manual calls for 18pd? Would going from 16 to 18 make this stop? Doesnt take long at all for it start overflowing. Any help or suggestions would be greatly appreciated....Thanks in advance.
Old Sep 19, 2004 | 12:56 AM
tomatocity's Avatar
Re: Overheating problems with 96' T/A
What was the last thing you or someone else did to your car?
Old Sep 19, 2004 | 01:54 AM
nothing
have not done a thing thought it might have been the heater loseing water but heard it coming out the reserver and seen who ever had it before had put a 16 pound cap on it .car runs real good and as clean as you could get but the heat is not good.
Old Sep 19, 2004 | 02:42 AM
tomatocity's Avatar
Re: nothing
Do the simple things and start with checking the thermostat to see if it is functioning properly. Shoebox's Tech Page is a good resource for this. Why the 16 lb cap concerns me. Is your radiator clean internally and flowing water freely? Check to see if the radiator is clean externally and can flow air. Are the radiator hoses in good shape and that the hose that feeds the water pump is not collapsing. If you have lost all of your coolant, this would be a good time to remove the radiator; clean the exterior; make sure air flows through it and the A/C condenser, that the hoses are not breaking down internally, etc. Do this right so you don't have to do it again anytime soon.
Hopefully you get more replies from someone(s) that have hands-on experience with thier LT1.
Tim
Fastbird93
Apr 9, 2016 07:01 PM
shroyvin56
Apr 19, 2015 09:40 PM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
