whats these hoses for
Old Sep 19, 2004 | 02:11 PM
92rslt1's Avatar
what are the hoses for that hook to each head in the back on the lt1?? looks like coolant but the motor i got didnt come with them so i cant tell.
thanks
jeff
Old Sep 19, 2004 | 02:19 PM
bunker's Avatar
Re: whats these hoses for
Those are air bleed off lines, it prevents air bubbles from forming in the heads & promotes better cooling while preventing hot spots developing etc...
Matt.
Old Sep 19, 2004 | 10:06 PM
92rslt1's Avatar
were do they run?? what do they run to?
Old Sep 19, 2004 | 10:14 PM
It eventually runs to the radiator. The routing depends on the year.
93-94
95-97
Old Sep 20, 2004 | 08:58 PM
92rslt1's Avatar
wow those help alot do you have any for the emission routing.. thanks alot
Old Sep 20, 2004 | 09:32 PM
kingman109's Avatar
go to his tech page - best website ive ever seen regaurding F-bodies -
Old Sep 20, 2004 | 09:38 PM
Valkyn71's Avatar
they are a device designed by satan himself specifically to irritate me durring my head swap.
Old Sep 20, 2004 | 09:42 PM
pelebkf's Avatar
I wanted to weight in on this. these lines are supposed to be a intrical part of the lt1 reverse cooling system but can anyone explain why the majority of SB chevys do not have these lines? (besides the fact that the majority are not reversed cooled) and Are they really that nessesary?
Old Sep 20, 2004 | 10:01 PM
Eddie95Z28's Avatar
Other SBC's have coolant crossovers in the intake itself. The LT1 uses a "dry" intake in that there is no coolant flowing through it. So it uses the "external" crossover tube instead.
Old Sep 20, 2004 | 10:09 PM
pelebkf's Avatar
Man I love this board quick good answers thanks eddie I never knew that. I guess I will look for theose rubber washers now to put this back on.
Old Sep 21, 2004 | 11:18 AM
Eddie95Z28's Avatar
Actually you should probably buy new ones. They are pretty cheap and that would be a crappy area to find out you have a leak after everything is together.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
